I have problem with connection on isometric.
Isometric doesn't show any connection to other lines. It worked at the beginning but now it doesn't any work.
I also remake few lines and they worked little while and then connections disappeared??
Make sure the "Show end connection annotation on Iso" is enabled for the Iso style being used and for the specific end connection type:
I hope this helps.
Dan
I have checked these and there are OK.
When I make new line next to old ones it works just fine but the old ones doesn't.
I don't know if its possible to send my model to someone who can check it?
I have the same problem. No connections are showing, neither to sheet continuation nor drains. "Show end connection annotation on Iso" is checked.
When I change to a diffrent Iso styles it works fine but i want to use this one..
Any ideas?
