AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometric Template Blocks
6 REPLIES 6
870 Views, 6 Replies
Hi Yawl
I need to insert a check stamp into the iosmetric drawing template and am inserting it into the title block dwt file using the Setup Title Block within project Setup.
Unfortunately the block will work for a while but then fail and disapear from the template.
Also any modification of the template also causes the block vanish.
Anybody seen this before?
Robot wink
Cheers Ian W
6 REPLIES 6
TomislavGolubovic
The title block inside the .dwt file has to be called "Title Block"
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
in reply to: TomislavGolubovic
Tom
Thanks for your reply
The block inside the dwt file is currently called 'Title Block'. as recomended,
but the inserted blocks still dissapear,
They are still referenced in the dwt as blocks but do not display.
Ian Whistler
Robot LOL
TomislavGolubovic
Is there any chance you can upload the Iso Style you are using, with the .dwt file included? Upload it here as a zip?
Tomislav Golubovic
Autodesk, Inc.
Solved my problem.
BSchwartzkopf
in reply to: celeste56
Can you let us know how you solved your problem? I am having the same issue with a customers jpg on the title block. I thought it was just an Autocad anomally but I would like to fix ours also.
celeste56
in reply to: BSchwartzkopf
These are all my steps, some are probably redundant.  I have a dwg that the company wants to use for a title block.  I made the dwg into a dwt.  Then I added a Tiff image of the company logo. I made the everything into a block called Title Block. Save.  Went to project setup, isometrics, title block..searched for the location of the title block dwt.  The went into the edit feature to make a BOM and drawing area. Does this help?
”Boost
