Is there any way to set the coordinates in pipeline continuation to format N S EL? And how can I make to appear the isometric sheet number next to the called line tag number (See attached file).
Fernando
Go to project set-up - Isomoetric DWG setting-Annotations...
in the end connection annotations, you have Iso sheet continuation (to) and Iso sheet continuation (from)
select one by one and type the what you want to appear in the "connection text prefix"
don't forget to tick "show end connection annotation on iso.
also tick the property names.
"append coordinates and elevation
and down you can name your coordinate prefixes.
hello friend,
what attribute we need to set for sheet number display at connection?
i tried SH# but cant get any lead in that.
Dear Friend,
Where actually your sheets numbers don't appear is it on the iso dwg or the title block(frame)
If on the iso dwg ...you should follow the steps mentionned before.
if on the title block then refer as follows.
go th title block setup in project setup. then title block attributes... a window will pop "insert title block attributes"
on the tab add attibutes, in attribute category select all.then try to find "sheet" and click on map attribute.
on the map attribute window, on the block attribute side, find TL and SH.map both of them total count and sheet on the plant 3d attributes side respectively.
it should work.
BUT THE FIRST THING DO CHECK YOUR ISO STYLE.WHETHER IT IS A3 FINAL OR CHECK A3 ETC.
.....IT MAY COMES THAT YOU HAVE MADE THE SETTINGS ON A3 FINAL AND GENERATING ISOS ON CHECK A3, IT WONT WORK....
DONT FORGET TO KUDOS
I want like this..
now drawing number is coming and i required Sheet number.
in title block,
i have already set all attributes..
To fix the Coordinates part try this:
Daniel
