AutoCAD Plant 3D General
PatrickByrne
Message 1 of 4 (252 Views)
Isoconfig.xml and IsoSymbolStyles.dwg files from 2012 into 2013
252 Views, 3 Replies
11-29-2012 04:19 PM
I am setting up a project in Plant 3D 2012. When we upgrade to 2013 is there anything I need to do to migrate the files Isoconfig.xml and IsoSymbolStyles.dwg from 2012 into 2013 or can I just copy them into the new Isometric folder.
Valued Mentor
Rich.O.3d
Message 2 of 4 (239 Views)
Re: Isoconfig.xml and IsoSymbolStyles.dwg files from 2012 into 2013
11-30-2012 06:06 AM in reply to: PatrickByrne
Pretty sure that you just open the 2012 project in 2013, it will ask you if youwant to migrate it.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Product Support
VinodBalasubramanian
Message 3 of 4 (205 Views)
12-02-2012 07:31 PM in reply to: Rich.O.3d
Hi Patrick,
Rich is correct. If you think this xml files are not added, you can add them to add files in the migration dialog and it will back up and migrate it as well.
Hope that helps.
Vinod Balasubramanian
PatrickByrne
Message 4 of 4 (187 Views)
12-03-2012 03:00 PM in reply to: VinodBalasubramanian
Thanks, I will try again later.
I had a problem with the Isometric symbol for the Stub ends reversing in 2013 but worked okay in 2012.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
