I have set up a custom property called "SheetNum" at the Pipe Component level. I am using this property along with the Line Number to split the isometrics where necessary. Does anyone know how I can set up the File Naming to include this property e.g. Line Number-SheetNum?
To clairify, when you mention File Naming, where are you wanting the file name to appear? Are you wanting the generated Iso Sheet title to be "Line Number - SheetNum"?
Here is a link to a video of the process I went through that might help in what you are wanting to see.
https://chronicle.autodesk.com/Main/Details/ad8fea79-abd4-4143-9f32-a306b8406d69
Quentin Contreras
Technical Support Specialist
Quentin, thanks for your reply. I am sorry I was not specific enough. What I want is for the isometric file drawing name to be Line Number - SheetNum e.g. "P-1000-01.dwg" where "P-1000" is the Line Number and "01" is the SheetNum.
