Please take a look at the attached image. For some reason, a lot of my iso's will show the continuation symbol, when they are not required. Is this something I need to change in my configuration or is it a bug?
Are there any adjustments you made to the IsoConfig.xml? Also, have you tried to go to the Project Setup and adjusting the setting in the Isometric DWG Setting, Annotations. Try adjusting the End Connection Annotations and see if that helps to resolve the issue for you.
Quentin Contreras
Technical Support Specialist
