HI,
I did a FLOW METER iso symbol. Everything is correct, but I would like to add the TAG. For example: FIT - 4343.
If I use the point CP, the result is:
However, I would like to get the ISO symbol like that:
Is it possible?.
Thank you for all
Solved by jabowabo. Go to Solution.
Thank you, jabowabo.
I tried it, but I haven't got it yet, because I created my flow meter in the catalog and it is a valve, not an instrument. It doesn't have the same properties. And I have problems when I use IsoTag.
