I have been doing quite a bit of work to set up our 2014 iso engine, recently it has come to my attention that vertical iso dimension text displays 'right to left', even although my dimension style states text to be orientated 'left to right'. See below, iso dimensions are fine, but the vertical dimensions appear backwards as stated.
Anyone else having similar problems with iso dim styles?
Solved by VinodBalasubramanian. Go to Solution.
This is a known issue and has been already reported to our development team. They are actively working to fix this issue. Will keep you posted on the updates.
This happens if the polylines are not 100% vertical and this causes the dimension text to flip so that is effectively drawn on top.
If you draw a line at a greater angle you will be able to see how this flipping of the text happens.
