AutoCAD Plant 3D General
PatrickByrne
Message 1 of 4 (244 Views)
Is it possible to erase the second flange but keep gasket and bolts
244 Views, 3 Replies
12-17-2012 12:46 PM
At the end of a pipe i need to keep the bolts and gaskets, is it possible to erase the second flange but keep the bolts and gaskets.
We could add in a piece of equipment and continue from that but I just want to know if it is possible.
Active Contributor
hendriksegveld
Message 2 of 4 (213 Views)
Re: Is it possible to erase the second flange but keep gasket and bolts
12-18-2012 06:47 AM in reply to: PatrickByrne
you can make the second flange in the properties status = existing (normally status=new)
Distinguished Contributor
Arun_Kumar_K
Message 3 of 4 (152 Views)
12-25-2012 01:59 AM in reply to: hendriksegveld
Thanks, it solved my problem too.
Arun_Kumar_K
Message 4 of 4 (135 Views)
12-26-2012 06:50 AM in reply to: Arun_Kumar_K
Similar to this, I have an issue in P&ID. How to keep the "Other vendor scope" lines and valves away from valve schedule and line list.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
