I am having trouble with the color of the Inventor Equipment models I import into Plant 3D. I cannot change the color of the Equipment, which
is very important in our models because we color code our Equipment to distinguish between temporary and Final Equipment. I have even tried exploding them , which is bad because we have nozzle information on them and even that would not allow me to change the color.
Any ideas?
I do a lot of equipment design in Inventor to be placed into our plant 3D model to run piping. I have ran into a problem with the color of the equipment, it will not take on the color of the layer it is placed on. The equipment model, when selected will only show the edges colored to the right layer color. you also cannot even manually change the color in the properties menu. This is a real problem because we use a lot of color coding for different stages of equipment completion and in progress. Does anyone have any ideas? I thinnk its someting to do with materials converting from inventor to plant 3D but have not found a solution.
I use Inventor for creating my equipment with piping connectioins and place them into plant 3d where we run our piping. I have ran into a real problem though. When i import my equipment i cannot get it to take on the color of the layer it is placed on. it remains gray . the only way to get it to change color is to turn off materials in the visual styles manager or explod the equipment which loses its piping connections . is there any way around this? jbland2013@live.com
i used inventor on plant modelling before we bought plant 3D. It is WAY better than plain autocad, but plant 3D is WAY better than inventor for plant modelling. While inventor creates solids like no big deal - it totally sucks in big assemblies. the trouble with inventor - you cannot move parts and subassemblies! well, you can, but not directly, like in autocad. instead of moving you have to use a thing called "constrains" - which is a total pain in the rear when it comes to big assemblies.
and while it is way easier to create equipment in inventor than in plain autocad - it is even easier in plant for most of the time. Yes, plant has it's weak points - and lots of them - but it economizes you lots of time.
i still use inventor when I need to create a custom equipment - the one that cannot be done with pure plant means,then i expost in into Plant 3D.
as for piping - i have inventor routing systems, and for general purposes it's ok. But it is not as precise as plant 3D and libraries for valves and stuff are SO better in plant.
also plant creates 2d ( othros) way faster than inventor, and way easier.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
I am having this exact same problem: I cannot change the color of equipment I have imported. Did you happen to ever get a response?
As far as I'm aware you cannot change colour of imported equipment. It needs to be brought with correct colour into P3D.
that is really weird, because equipment imported from Invetor usually have color of the layer. i can change color easily by changing the layer or changing the color in properties. chake again if you can change color from properties.
