I am having an issue with my piping insulation showing in simulate 2011. Insulation shows up fine in Plant3d 2011 when insulation is toggled on. If I toggle insulation on in Plant3d and save, when I open the dwg in Simulate the insulation is not shown everything elase in the model is fine just no insulation. I have tried many times and deleted all nwc files just in case. It use to show insuation fine. Anyone have any ideas?
norrmaly if you set the visualization of insulation ON in Plant3D and save the file, after Add it in Navisworks it works. Can you attach the DWG file to prove it?
