I am having an issue that the insulation does not look right and has an open end to it (left on screenshot)...
to the right on the pipe run is a flanged valve which looks fine, because the hallow end is covered by the flange...
Is this a known issue? The pipe should close off similarly to actual insulation...
Thanks in advance!
Stassel
