Hi Autodesk Support,
I have problem whine I generating the isometric, I had put the instrument in the model with tag no. after generated the isometric he give me missing symbol and also without tag no.
For more clarification refer the attached file
Ahmed Helal
Solved by Ahmed1081975. Go to Solution.
Can i able to reproduce this in the project that you have sent to me earlier. If not, do send me your model for investigation.
Thanks Ahmed. I will take a look into this issue as well.
Can you also tell me the line number for which I need to extract the ISO to see the missing instrument symbol ?
Below is the correct workflow for getting your instrument symbol in isometric.
1] Open the isoAcadSkeyBlockmap.xml and add the line: <SkeyMap SKEY = "II??" AcadBlock ="Instrument-Dial"/>
2] 2] Open the IsoSymbolStyles.dwg and create a symbol called Instrument-Dial that has a single port.
3] Edit the part in the model to: SKEY=IIFL,TYPE=INSTRUMENT-DIAL
Result (Instrument shown in magenta):
Hope that helps.
Hi Vinod
I reviewed your replay below which is totally worked fine for me as well. But for some reason numbering the instrument which will appear in the ISO is missing.. Any idea how can I have tag number in the istrument. number show in BOM hewever.
see attached
Thanks.
