AutoCAD Plant 3D General
Ahmed1081975
Message 1 of 9 (446 Views)
Instrument Symol Missing
446 Views, 8 Replies
05-06-2013 11:56 AM
Hi Autodesk Support,
I have problem whine I generating the isometric, I had put the instrument in the model with tag no. after generated the isometric he give me missing symbol and also without tag no.
For more clarification refer the attached file
Ahmed Helal
Product Support
VinodBalasubramanian
Message 2 of 9 (422 Views)
Re: Instrument Symol Missing
05-06-2013 09:29 PM in reply to: Ahmed1081975
Can i able to reproduce this in the project that you have sent to me earlier. If not, do send me your model for investigation.
Vinod Balasubramanian
Ahmed1081975
Message 3 of 9 (408 Views)
05-07-2013 12:18 AM in reply to: VinodBalasubramanian
Yes Please Same Project
Ahmed Helal
Product Support
Message 4 of 9 (377 Views)
05-08-2013 01:33 AM in reply to: Ahmed1081975
Thanks Ahmed. I will take a look into this issue as well.
Product Support
Message 5 of 9 (373 Views)
05-08-2013 01:55 AM in reply to: VinodBalasubramanian
Can you also tell me the line number for which I need to extract the ISO to see the missing instrument symbol ?
Ahmed1081975
Message 6 of 9 (361 Views)
05-08-2013 05:40 AM in reply to: VinodBalasubramanian
The line No. is  (CP517-1-DWG-EMI-030)
Ahmed Helal
Product Support
Message 7 of 9 (324 Views)
05-14-2013 06:00 PM in reply to: Ahmed1081975
Below is the correct workflow for getting your instrument symbol in isometric.
1] Open the isoAcadSkeyBlockmap.xml and add the line: <SkeyMap SKEY = "II??" AcadBlock ="Instrument-Dial"/>
2] 2] Open the IsoSymbolStyles.dwg and create a symbol called Instrument-Dial that has a single port.
3] Edit the part in the model to: SKEY=IIFL,TYPE=INSTRUMENT-DIAL
Result (Instrument shown in magenta):
Hope that helps.
Ahmed1081975
Message 8 of 9 (305 Views)
05-15-2013 11:53 AM in reply to: Ahmed1081975
Thanks Very Much Vinod Finally it's working well
Regrdas,
Ahmed Helal
samans
Message 9 of 9 (152 Views)
12-10-2013 11:31 AM in reply to: VinodBalasubramanian
Hi Vinod
I reviewed your replay below which is totally worked fine for me as well. But for some reason numbering the instrument which will appear in the ISO is missing.. Any idea how can I have tag number in the istrument. number show in BOM hewever.
see attached
Thanks.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
