AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Install 64bit Plant 3D on Windows XP
4 REPLIES 4
812 Views, 4 Replies
After installing Plant 3D 64bit using a network license the P&ID menus and 3D piping menus do not show up in the workspaces using the ((Unnamed Profile)). This is out of the box install, shouldn't they show up in the workspace just as they did with the 32bit install using the ((Unnamed Profile))? What Am I missing?
4 REPLIES 4
lopezjo
Can you try loading PnP.cui manually?
Did you have the BETA installed? From readme file:
After un-installing AutoCAD Plant 3D 2011 Beta 2 and installing AutoCAD Plant 3D 2011, your workspace may not load. To load the 3D Piping workspace, use the menu command to load PnP.cuix.
Hope this helps.
Jorge Lopez
Software Architect
Autodesk Plant Solutions
azmand01
in reply to: lopezjo
Having the same problem here.
I don't understand what you mean by loading from Menu.
I can only try as a Partial Customization File that is not really ideal.
It should be loaded with the main acad.cuix.
Anyone with any other idea in how to fix this?
dave.wolfe
in reply to: azmand01
With Plant 3D, the pnp.cuix is supposed to be the main customization file. To make sure this is set, go to Options -> Files -> Customization Files -> Main Customization file.
Is that set?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Tags (1)
azmand01
in reply to: dave.wolfe
Thanks Dave,
Yes that is set, and it was set before.
I was able to load CUi using menu command. To avoid that occuring again I saved a new profile with correct settings.
”Boost
