AutoCAD Plant 3D Forum
Import of 2011 templates into 2012
3 REPLIES 3
rh
383 Views, 3 Replies
I'm trying to import templates that are done in P3D 2011 into P2D 2012. I get an error message saying "Could not load template - invalid file". Can somebody help?
3 REPLIES 3
DACOMA3
in reply to: rh
Has anyone else seen this error message?
I am not trying to import equipment templates from a previous version, but i did change the path for the equipment template folder location to point at a different folder because i wanted my templates to be in a "network" location for all users and now when i go to bring in a piece of equipment from the templates folder i receive the same error message "could not load template - invalid file"
pendean
in reply to: DACOMA3
The error message simply means there is a problem / corruption in the file. Fix it.
DACOMA3
in reply to: pendean
Obviously there is a problem that needs to be fixed. I posted my question to see if anyone has seen the error message and had a possible solution.
”Boost
