AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Imperial to Metric connection 2014
3 REPLIES 3
alvaro.nimasco
929 Views, 3 Replies
after enable "This joint connects imperial to metric components", I can't connect imperial to metric and also can't connect metric to metric nor imperial to imperial which I could before enabling. In 2013 version, didn't have this issue.
The imgs show a SW example trying to connect a PL pipe
thanks
3 REPLIES 3
So, nothing to do here ?!
tough for releasing isometrics
regards
In 2014 the joint settings have changed slightly.
You now need to create a specific connection for each joint to indicate whether it is imperial-metric or not.  If you look at a default configuration, you will see that there is now a Buttweld Joint and a MixedButtweld Joint.  The checkbox in the user interface is now definitive – if it is ticked the joint is mixed only.
Therefore you need 2 different SW-PL joint settings, 1 mixed and the other not.
Hope this helps.
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
batone79
in reply to: AndyDavisCadline
I wanna say thanks to Autocad Plant 3d Developers to make my live better with this improve....
pufff...there are not things to change, you know? and touch that..
Bravo.!!!
”Boost
