after enable "This joint connects imperial to metric components", I can't connect imperial to metric and also can't connect metric to metric nor imperial to imperial which I could before enabling. In 2013 version, didn't have this issue.
The imgs show a SW example trying to connect a PL pipe
thanks
In 2014 the joint settings have changed slightly.
You now need to create a specific connection for each joint to indicate whether it is imperial-metric or not. If you look at a default configuration, you will see that there is now a Buttweld Joint and a MixedButtweld Joint. The checkbox in the user interface is now definitive – if it is ticked the joint is mixed only.
Therefore you need 2 different SW-PL joint settings, 1 mixed and the other not.
Hope this helps.
Andy
I wanna say thanks to Autocad Plant 3d Developers to make my live better with this improve....
pufff...there are not things to change, you know? and touch that..
Bravo.!!!
