AutoCAD Plant 3D Forum
ISSUE WITH 45 TEE's
9 REPLIES 9
Message 1 of 10
philip
604 Views, 9 Replies
ISSUE WITH 45 TEE's
Started a project in 2012 and had things working okay had run some isos off and all was good (image "45-2012")
Then migrated to 2013 and added a whole lot of new pipes reran some iso which have changed and now am finding that 45 tee's are not working anymore(image "45-2013")
Have started a new project and created a "custom part" and found that the issue is there still (thought it might be some of our custom Isometric symbols).
is this a bug with 2013??
9 REPLIES 9
Message 2 of 10
Venkatesan.A
in reply to: philip
Philip,
Thanks for highlighting.
A change request has been opened relating to this issue.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 10
philip
in reply to: Venkatesan.A
any idea if this may come out as a fix this year or will it be in the next release of Plant (2014)?
Just so i know either to use or not to use 45 tees in upcoming projects.
Message 4 of 10
Venkatesan.A
in reply to: philip
Sorry for the late reply, I am in discussion about this issue, please give me some time.
I will update you asap.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 5 of 10
philip
thanks.
Message 6 of 10
pata825
in reply to: philip
Have we heard anything on this yet? I am having similar issues with lateral. Anyone found a good workaround? was thinking about grabbing the block from 2012.
Message 7 of 10
philip
in reply to: pata825
nothing as yet, I ended up doing a lot of manual works to get it looking half right so we could get job out.
Message 8 of 10
pata825
in reply to: philip
Manual work to your isos, or were you able to figure out a workaround to get the isos to come out right?
Message 9 of 10
philip
I changed the isos after they were made by Plant.
Only workaround i can think of is to create a user SKEY, i have not tried this yet.
Message 10 of 10
Venkatesan.A
A Hotfix has been issued that address this issue. The link is as below.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20164796&linkID=14116968
Let me know if this works fine for you.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
”Boost
