I AM TRYING TO CREATE A SYMBOL FOR A CUSTOM VALVE. BUT SHE IS NOT GENERATING Corret.
FOLLOW PICTURE.
Yes,
the problem is that the centerlines of the valve is excentric. The iso generator can not handle this kind of excentricity.
You can set up any kind of valve, they will work in the 3D model but will be a problem when you generate ISOs.
The iso generator can handle properly valves up to 4 ports (4 way valve), but the centerlines shoulde be perpendicular each other and should cross in one point (the center of the valve).
