AutoCAD Plant 3D Forum
ISO creation error
7 REPLIES 7
Message 1 of 8
Jorgen1990
2379 Views, 7 Replies
ISO creation error
Hello!
I tried to create an isometric from a pipeline and got an error message "errors were encountered". Error log and picture of the pipeline are attached. What could I have done wrong? I have managed to successfully create isos from other pipelines in the same project.There are no disconnections in the pipeline, everything should be OK.
The pipeline is the yellow one in the picture.
Jörgen
7 REPLIES 7
Message 2 of 8
Adsk_amitb
in reply to: Jorgen1990
Can you provide the PCF please?
Message 3 of 8
Jorgen1990
in reply to: Adsk_amitb
Yes, here it is. Program didn't name it by the line number, but named it UserDefinedLine.pcf for some reason.
Here is the download link for PCF file: http://www.speedyshare.com/file/cgaW2/UserDefinedLine.pcf
Jörgen
Message 4 of 8
karthik.nathan
Hi Jörgen,
I was able to generate isos successfully for Check, Final and Stress. Any chance you can attach the IsoConfig.xml and the Iso.dwt for which the iso creation for this pcf is failing.
Karthik
Message 5 of 8
I think Jorgen and I are in the same boat.
I ran t he ISO creation before and it worked, but now I get the " Errors were encountered" message.
Can you help me out with this problem please? I appreciate your assistance.
Patrick
Message 6 of 8
Arun_Kumar_K
please do the following, its only a temporary work flow. Copy isoconfig file from other isostyle folder and paste in your required isostyle folder.
Message 7 of 8
Arun_Kumar_K
in reply to: Arun_Kumar_K
Make sure you keep a backup of your present isoconfig file.
Message 8 of 8
@Arun_Kumar_K
Could you please detail this step by step?
”Boost
