AutoCAD Plant 3D Forum
ISO annotations - can I modify them?
10 REPLIES 10
Message 1 of 11
1300 Views, 10 Replies
There are a couple things that come in with the text when I run an ISO that I would like to turn off but I can't figure out how.  I know the annotation style is Adskisoannotation, but is there a way to get in there and customize it?  Or is that what I would even do?  Anyway, all the size call outs come in with an "NS" after the size, i.e. 4" NS.  Also, I would like to change the "X" in the reducer size callout to be a lower case "x".  It comes in upper case. There is no "anno" anything when I go in to "edit ISO symbols" either.  Out of ideas. Please help!
Tags (3)
10 REPLIES 10
Message 2 of 11
I was able to get rid of the "NS" in the isoconfig.xml files and thought I found where to change the "X" to lowercase but that one didn't work.  Still investigating that one....
If anyone needs to know where the "NS" configuration is, I have it written down and will forward if needed.
Message 3 of 11
jabowabo
There is a 'forceuppercase' option at the beginning of the isoconfig.xml.
Message 4 of 11
in reply to: jabowabo
Thanks so much.  It worked!  I don't know much about xml just yet but have been able to figure a few things out.  Again thank you.
Message 5 of 11
forrumako
how did you do?? because i met this problem also. pls tell me
Message 6 of 11
in reply to: forrumako
Is there a way to have a mix? I'm wanting Material, Description, Sch./Class  to be upper case but Qty & ND to be lower case. Am think you would need to set the first Forcecase to false  then have other Forcecase to individual areas for Material , Description &  Sch/Class?
Anyone able to help?
Message 7 of 11
dave.wolfe
You can create duplicate columns but that have upper case values, by setting up a calculated property (PLANTDEFINECALCPROPERTIES command) using something like this:
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 11
in reply to: dave.wolfe
Thanks will look into using this.
Message 9 of 11
scarughi
How did you get rid of the "NS" in the isoconfig.xml.? Can you let me know how
scarughi
Message 10 of 11
julie_havard
If I want to increase the size of the iso arrow, is it possible in isoconfig.xml and is it the good way?
Message 11 of 11
jabowabo
in reply to: julie_havard
If you mean the FlowArrow, you can use Block Editor in the IsoSymbolStyles.dwg file to scale it as required.
”Boost
