I get the following error when i try to generate a spools set of isos's. Iso Creation start time : 3/18/2014 5:15:20 PM Iso Creation finish time: 3/18/2014 5:15:27 PM Duration : 00:00:06 Output folder : R:\352-UMICORE\002 - FEED CMB PROCESS\DRAWINGS\Plant 3D Umicore\Isometric\FnLSpools_ANSI-B\ProdIsos\Drawings ------------------------------------------------------------------------------- 1 Isometric(s) were not able to be created: R:\352-UMICORE\002 - FEED CMB PROCESS\DRAWINGS\Plant 3D Umicore\Isometric\FnLSpools_ANSI-B\PCFs\1001-HBr.pcf ------------------------------------------------------------------------------- INFO - Loading input: 'R:\352-UMICORE\002 - FEED CMB PROCESS\DRAWINGS\Plant 3D Umicore\Isometric\FnLSpools_ANSI-B\PCFs\1001-HBr.pcf' WARNING - SKEY to block mapping not found for current component. Name : FLANGE Item Code : SPACER, FORGED CARBON STEEL, RAISED FACE TO FLAT FACE, 2", 150 LB, PVDF LINED, ASTM A516 GR 70 -2 Coordinates: 317.5614 590.0000 192.2500 2.0000 LFL,317.5614 590.0000 193.2500 2.0000 LFL SKEY : LLP-FLANGE INFO - Loaded '1' model(s). INFO - Processing: '1001-HBr'. WARNING - Invalid filter expression: '(Type = 'Elbow' OR Type='Bend') AND NOT ANGLE IS NULL AND [ANGLE-CDEG] <> 9000 AND [ANGLE-CDEG] <> 18000'. WARNING - Invalid filter expression: '(Type = 'Elbow' OR Type='Bend') AND NOT ANGLE IS NULL AND [ANGLE-CDEG] <> 9000 AND [ANGLE-CDEG] <> 18000'. WARNING - Invalid filter expression: '(Type = 'Elbow' OR Type='Bend') AND NOT ANGLE IS NULL AND [ANGLE-CDEG] <> 9000 AND [ANGLE-CDEG] <> 18000'. FAILURE - eInvalidInput -------------------------------------------------------------------------------
