AutoCAD Plant 3D General
New Member
Message 1 of 2 (117 Views)
ISO Creation - Modifying ISO Style Resulting in Errors (2013)
117 Views, 1 Replies
09-05-2013 07:18 AM
I'm trying to generate ISOs using "FInal_ANSI-B". The problem is all the text/annotations/symbols are scaled down 25 times. When I go in to the Iso Themes tab and modify the annotation text and symbol scale to be x25 what it currently is, I get errors in ISO creation and the Live Preview doesn't resolve.
Product Support
Martin_Stewart
Message 2 of 2 (95 Views)
Re: ISO Creation - Modifying ISO Style Resulting in Errors (2013)
09-06-2013 04:13 PM in reply to: paulyassa
To figure out why this is happening, first check what dimension style and test style your Iso style is using. In Project SetupIsometric DWG Settings/Title Block and Display, select the Iso style and then “Setup Title Block…” Then select “Iso Themes”. The Default Theme Dimension Style is listed there. Typically this style is “AdskIsoImperial”. Whatever style is there, open it and select Modify and check the sizes there. Adjust as needed. Same thing with Text Style.
If this resolves your question, please check this as “Solved” so others can find the answer as well.
Martin Stewart
Support Specialist
Product Support
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
