Hello
Today I've seen that the dirctory for the tool palettes became huge dimensions over 2 GB.
I think this is caused when switching the dynamic tool palette on/off. The palettes and the pics (bmp) will be copied into the directory every time I switch on.
(I don't need the palette for the piping specs, but for the pipesupportspec.)
How can I prevent these blow up of the directory?
Thanks Guido
Solved by Dan.Scales. Go to Solution.
Solved by dave.wolfe. Go to Solution.
Hi
I can't reproduce this here.
Could you provide the exact steps that cause the tool palette folder to increase in size?
Dan
I don't know why and when P3D copies all the files into this directory. May be it depends on the network path like Dave wrote...
I have turned the palette on and off this morning, and the directory did not increase....
Hello Dave
how can I create an own palette with the parts of the 'pipesupportspec'?
G
If you disable the dynamic tool palettes you can still use the support spec by renaming the palette before disabling.
Dan
