Hi, good morning
How are made, or where can i found other ladder types for plant 3d?
In ladder set up dialog,only "type1" can be choosen.
I need a ladder like the attached image.
Can i modify the "type 1" ladder and save it as "type2"? How it`s made?
Thank you very much
Solved by quentin.contreras. Go to Solution.
The structural content for the ladder type 1 is the only one that is editable and cannot be saved as something different for modification. If you are needing another ladder design you will have to manually create a 3D model for it.
Quentin Contreras
Technical Support Specialist
