I try to take out the blind flanges automatic dimention for the ISO.
My dimensions setting is as attach.
The blind flanges and caps didn't check anything....., but it still generate the dimention....
I am having the same problem. Wondering if Autodesk has had any revolution?
thanks
Depending on the size of the pipe you may need to make the same adjustment to thee other Iso Themes not just the Default theeme
Thanks, i went through all Iso styles and ticked the blind flange dimension off, however it did not solve the issue. Please refer to the attached snapshot.
thanks
