AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to route jacketing Pipe?
1 REPLY 1
640 Views, 1 Reply
HIi I am using AutoCad Plant 3D 2014.
I want to know, How to route Jacketing Pipe in our 3D model?
1 REPLY 1
Asimo5000
Hi
Have you thought about creating a pipe in a Catalog, use matching pipe OD's as per your standard and then for the visual aspect, use D and D2 = the OD including jacketed segments.
With an object like this, edit the Long description and Long Description (size) to show "..... X" ND...., JACKETED"
Thats one way to do it, if you want to add jacketing to an existing pipe, that could be done with a sleeve component (maybe)
”Boost
