Hello.
I have P3D 2013.
I want to rotate the view cube when I'm making a ortho view. How can I do that? I tried to left click and choose "rotate", but then I just move the cube and don't rotated it.
Is it possible to import a dumb solid (not shown as a wireframe) into Inventor from P3D? I would like to make a 2D drawing of the P3D modell in Inventor.
Regards
Therese
Solved by Rave.Tam. Go to Solution.
Thanks for your answer.
So I should have the opportunity to rotate the view cube when I defines the ortho view? Maybe I need a service pack?
When I use "exporttoautocad" and opens the DWG in Inventor, the model is shown as a wireframe and not as a solid, see the picture as attachment.
Regards
Therese
