AutoCAD Plant 3D Forum
How to rotate the ortho view cube and import a model to Invenor?
3 REPLIES 3
1753 Views, 3 Replies
Hello.
I have P3D 2013.
I want to rotate the view cube when I'm making a ortho view. How can I do that? I tried to left click and choose "rotate", but then I just move the cube and don't rotated it.
Is it possible to import a dumb solid (not shown as a wireframe) into Inventor from P3D? I would like to make a 2D drawing of the P3D modell in Inventor.
Regards
Therese
3 REPLIES 3
Rave.Tam
If you are trying to make 3d ortho view, it its not supported until 2014 version. But not sure why viewcube does not work.
Yes, you can just use exporttoautocad command to convert a drawing to a dumb AutoCAD 3d model.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
in reply to: Rave.Tam
Thanks for your answer.
So I should have the opportunity to rotate the view cube when I defines the ortho view? Maybe I need a service pack?
When I use "exporttoautocad" and opens the DWG in Inventor, the model is shown as a wireframe and not as a solid, see the picture as attachment.
Regards
Therese
Rave.Tam
You could try installing the latest Service Pack.
For the DWG, it seems you're opening the drawing directly. Can you generate 2d drawings from that? From my memory, you can import a 3d dwg as an assembly/part. Then you can use that to create a 2d drawing.
Anyway, i don't have inventor now but when i open up in Inventor Fusion and it shows properly.
”Boost
