AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to create a Project start using SQL Server
5 REPLIES 5
FrankSH
1653 Views, 5 Replies
In this thread: http://forums.autodesk.com/t5/AutoCAD-Plant-3D/SQL-Server-Setup/td-p/2872090
It talks about how to convert a project based on SQLite database to SQL Server
Here my question is how to create a project which starts from using SQL Server?
Does anyone who knows about this or have experienced with this.
Thanks.
Tags (1)
5 REPLIES 5
Layout-Bob
in reply to: FrankSH
Allthough I have not done this yet, the command should be "PLANTCONFIGUREDATABASE". hope this helps you out.
DarrenP
in reply to: Layout-Bob
i think its this white paper:
DarrenP
FrankSH
in reply to: DarrenP
Thanks, Darren
This dos will be helpful.
I'll try on that.
Thanks~
FrankSH
Tags (1)
FrankSH
Thanks, Bob
This is the command that for change database type
I've seen that in that document. That document is really helpful
DarrenP
i have attached the whole zip file:
DarrenP
”Boost
