AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to change the displayed unit of pipe diameter NS to MM(millimeter)
1 REPLY 1
2445 Views, 1 Reply
Hello all,
Does anyone know if there is anyway that i can set or change the displayed pipe diameter unit NS to MM ?
By default, i get NS when i create an isometric drawing,i use metric in my work,so i'd like to change NS to MM.You can see this on the image attached. So if anyone know how to do it, pls tell me.
Tags (1)
1 REPLY 1
Problem solved, go to the isoconfig.xml file, find<PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format="{0} NS" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
change the value of Format “{0} NS” to “{0} MM”.
”Boost
