AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to add label on the 3D pipe?
4 REPLIES 4
wuming250
968 Views, 4 Replies
How to add label on the 3D pipe (such as high pressure dangerous...). I try to use the "imprint", but the program say the 3D is not a 3D object.
There is any simple to put label on the pipe, like the inventor?
4 REPLIES 4
dave.wolfe
in reply to: wuming250
I've seen a Lisp that creates 3D text. You can also follow these steps:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=4248500&linkID=9240615
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
wuming250
in reply to: dave.wolfe
The problem is the pipe is not considered 3D object. I try this methed. it does not work.
dave.wolfe
It does work, the link I posted is talking about unioning the extruded parts of the text together.  I found a link to the Lisp file that lets you create 3D text easily.
http://cadtips.cadalyst.com/create-text/3d-text
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
wuming250
Maybe I did not say it clearly. The lisp you provide is for 3D text. I am trying to add text to the pipe surface. To make it  look like someone add label to the pipe surface.
”Boost
