Hi
after P3D SP1 came a hot fix with 'IsoSkeyAcadBlockMap' and 'IsoSymbolStyles'.
In my master project I've defined own symbols and their mappings.
How can I handle this problem? I don't want to create all the symbols again!
Thanks Guido
I have same issue after installed SP1, the question how we can merge the new one with our one Symbol did??
Ahmed Helal
You can do that by using the DesignCenter. Do that:
For all new projects:
For only one new project:
Please, let me know if this helps.
Best regards
Bernd
Small correction here. Change those files in those folders:
C:\Program FilesAutodesk\AutoCAD Plant 3D 2013 - <language>\ISOProjectTemplates
C:\Program Files\Autodesk\AutoCAD Plant 3D 2013 - <language>\UserDataCache\DefaultProject\Isometric
%Userprofile%\AppData\Roaming\Autodesk\AutoCAD Plant 3D 2013 - <language>\R19.0\<language>\DefaultProject\Isometric
