good morning, I'm working with autocad plant 3d 2014 and this is me close to anything that made throwing this error, if anyone knows how to fix please help donot how to fix it, and eh installed the program again and uh started secion with another user is aborting one mistake (FATAL ERROR : Unhandled Access Violation Reading 0x0018 Exception at 7d7d3cdh) , I was looking in the forums and not found anyone eh that has happened the same error.
thanks before hand
best regards.
Is this happening with just open project you are trying to open or does this happen with every project you open?
Is this happening with just open drawing you are opening in the project?
You might try to purge the data cache. Close out of Plant 3D and any other AutoCAD related tools. Run the following utility.
C:\Program Files\Autodesk\AutoCAD 2014\PLNT3D\PnPLocalDataCachePurger.exe
Quentin Contreras
Technical Support Specialist
