AutoCAD Plant 3D Forum
Grayloc fittings
1 REPLY 1
david.moore
1618 Views, 1 Reply
Grayloc fittings
Has anyone modified plant3d to use Grayloc fittings?  If so, what is required?
1 REPLY 1
bogdanov.y
in reply to: david.moore
You can use LAP joint connection in this case. And in the description of LAP Flange change to description which you need.
 It's posible to use couple conection. In this case to find this type of conection is necessary use Custom Hold Catalog in the COMON folder. It is the only place where I find this kind of connection.
”Boost
