AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Grating orientation
3 REPLIES 3
winner117
803 Views, 3 Replies
Grating orientation
Is there a way to change the orientation of the grating when you make a 3d plate with the grating hatch?
3 REPLIES 3
in reply to: winner117
I'm having problems with that too!  I tried to rotate the grating after I created it, but it really likes the orientation it started with... I created another GRATE_90 degree hatch in the .pat & can easitly get a regular ACAD hatch pattern, but I can't create a plate/grate from it (or even find it in the list to change the property of an existing grating).
So...  Since the program would not let me use my GRATE_90 hatch pattern to create a grate (even though ACAD likes it), I ended up revising one of the hatch patterns (TRANS) that they WOULD let me use:
*GRATE_90, Grated area 90 deg
0, 0,0, 0,.125
90, 0,0, 0,.03125
*TRANS, Grated area 90 deg
0, 0,0, 0,.125
90, 0,0, 0,.03125
;;original: (I revised *TRANS to be a 90 degree grate)
;;*TRANS, Heat transfer material
;;0, 0,0, 0,.25
;;0, 0,.125, 0,.25, .125,-.125
Not a "grate" fix, but it works... 🙂
Ahmed1081975
I have Another Proplem In Hatch Grating, it's come as solid hatch even if i change hatch scale
Please Advice
”Boost
