AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Graitec steel interfacing with plant 3d space
3 REPLIES 3
Arun_Kumar_K
340 Views, 3 Replies
Today I modelled a structural building in Graitec steel, and brought the building into Plant 3d space. Then generated Orthographic, it comes very nice and can be rated very good. ASD modelled elements in plant space have more errors, bugs and improper ortho generation.
3 REPLIES 3
ybogdanov
in reply to: Arun_Kumar_K
For solve problems of ASD models in Plant3D, probe to export structure as solids from ASD Project. In this case the ortho work fine.
Regards
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Arun_Kumar_K
in reply to: ybogdanov
Yes, it works. Good workaround you gave. How to do for Revit model to make solids?
Arun_Kumar_K
Gone through the document in net about how to convert Revit models into ACIS format. If Autodesk ppl informed about this, I would had used my Revit model in plant 3d space. The workaround is there in place, but nobody know except few ppl, those are not in Adsk.
”Boost
