AutoCAD Plant 3D General
Active Member
Message 11 of 17 (1,689 Views)
Re: Getting Fatal Error : Unhandled Access Violation Reading
01-06-2013 11:31 PM in reply to: MAD1975
Thanks for this post my firend.. Really good method. İt's worked awesome. :smileywink:
Active Member
Message 12 of 17 (1,589 Views)
Re: Getting Fatal Error P3D 2013
02-01-2013 04:34 AM in reply to: Rich.O.3d
I'am P3D user.(2013 - 64 bit.)
I have a similar problem about fatal error. having trouble trying to open the file with it. I can' t open my project.
Yesterday, I turned it off to save my project as normal.
When I try to open today has failed.
I need help urgently on this issue.
Thanks..
Valued Contributor
vannmannen
Message 13 of 17 (980 Views)
07-11-2013 11:54 PM in reply to: Rich.O.3d
I have suddenly got this problem now and my laptop does not have the path that is referred to:
C:\Users\xxxxxx\AppData\Local\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\GraphicsCache
I managed to delete ACAD-B017:409 but it did not help. This issue is serious. Please help
New Member
Message 14 of 17 (886 Views)
08-03-2013 06:36 AM in reply to: MAD1975
I am facing a problem with etransmit and email process on Civil 3D 2014. The first time I tried to email a file thru these commands the AutoCAD sent me a message "unhandled Access violation reading 0xbf3c5f40 exception at bed132434". I tried a few things some people suggested me on the forums but none of them worked (except the registry Im avoiding to modify). I reinstalled the .NET for my windows and even reinstalled my civil3d. After reinstallation, I dont recieve the mentioned message anymore but the cad gets frozen after sending. Otherwise, my outlook works normally..truly, I am running out of ideas. I am working on the new laptop (i5 processor) and everything else seems to work normally. please help me...thanks in advance,,daniel
New Member
Message 15 of 17 (535 Views)
Unhandled Access Violation Reading 0x000 exception 4b2116h
11-18-2013 05:54 AM in reply to: MAD1975
I am running autoCAD 2000LT and and got this fatal error message and not sure what it is or how to deal with it---any help would appreciated.
I am trying to fix it but afraid doing more damage
Thanks Chip
New Member
Message 16 of 17 (60 Views)
04-10-2014 11:13 PM in reply to: Rich.O.3d
Getting Fatal Error : Unhandled Access Violation Reading:Unhandled Access Violation Reading 0x94f45388 Exception at 1cd9072h。
Tried the Repair option. It didn't work.
Reinstalled Plant 3d 2013 after uninstalling everything 2013 related but it didn't work.
The program crashes at startup even if I start only the program and not a project.
Windows XPcard etc are all up to date.
 Is there something I should know to fix this ?
Valued Contributor
vannmannen
Message 17 of 17 (57 Views)
04-10-2014 11:18 PM in reply to: miquery
In fact, I managed to solve this. The path: C:\Users\xxxxxx\AppData\Local\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\GraphicsCache is there if you go to folder options and show hidden folders. Delete all files in the folder and then you should be back on track.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
