Hi
Just started a new spec on plant 2012 and had originally an option of 2 gaskets, 1 for SPW and 2. for Flat CNAF.
I removed the CNAF gasket from the spec as it was not picking up the SPW as first option but now the SPW is shown as "PH IMPERIAL GASKET", isthere a solution to this? (see attachment)
Also wanted to know if there is a way to show blots with imperial dia x metric length, i.e. 3/4"x110 on the iso MTO?
I had all this working on 2011 but now find that the ISOGEN dir (where I had all my isogen changes) has been deleted for 2012, is there a way of using the isogen setting with 2012?.
Jo
I can answer your first question. Not sure about the other two.
To substitute gaskets hold the CTRL key down then select the gasket, then select the substitution grip. NOTE: You will need to change to 2D Wireframe in order to actually pick the gasket.
