AutoCAD Plant 3D Forum
GF+ PE Pipe and fittings
11 REPLIES 11
Message 1 of 12
Kgokhankaya
3242 Views, 11 Replies
Hello
I  work in Autocad Plant 3D 2012 and I need to use GF+  PE Pipe and Fittings catalogue to create specs. Does anyone has faced this problem as me before.
Best wishes...
11 REPLIES 11
Message 2 of 12
JohnHolder
in reply to: Kgokhankaya
Not sure about other people.. but I found most of the specs are missing too much to be useful.
so I made my own specs after modeling all the fittings needed.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Message 3 of 12
patpat78
in reply to: JohnHolder
you can download complet gf catalog
http://autocad.autodesk.com/?nd=plant_content_packs
in europe section
Message 4 of 12
Autodesk Plant content team seeking your comment on the +GF+ content pack. Please read the readme file before downloading the content pack. Please let us know which materials of GF content do you use in your project?
http://autocad.autodesk.com/?autodownload=../secure/protected/Georg-Fischer-PVC-CPVC-Sch40-PVC-Sch80...
http://autocad.autodesk.com/ama/orig/plant/README__Georg_Fischer_PVC_CPVC_Sch40_PVC__Sch80_CPVC_Cont...
http://autocad.autodesk.com/?autodownload=../secure/protected/Georg-Fischer-PVC-C-PVC-U-ABS-Content-...
http://autocad.autodesk.com/ama/orig/plant/README_-_Georg_Fischer_PVC-C_PVC-U__ABS_Content_Pack.pdf
Looking forward to hearing from you.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Autodesk, Inc.
Message 5 of 12
bgorucu
in reply to: rajsekarpillai
Do you have any plans to create GF + PE catalogue? This one is missing.
Thank you
Bılent
Message 6 of 12
We are working on the priorities. Please vote your priority content pack requirement through Request Content Pack form.
http://autocad.autodesk.com/?nd=form__105
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Autodesk, Inc.
Message 7 of 12
patpat78
i think in the GF catalog PVC there are some problemes
for diameter 63 for exemple when we generate iso or in the line name it says "63mm" not only "63" it's a big probleme for us because we cant use the spec wtih mm at the end of diameter... any idea ?
Message 8 of 12
Please update the "NominalDiameterMap.csv" in your AutoCAD Plant3D root directory. To do that, Please download the attached file and replace existing file under "C:\Program Files\Autodesk\AutoCAD Plant 3D 2012 - English\".
Note:  It is a good practice to back up the existing file before replacing it with the updated
version.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Autodesk, Inc.
Message 9 of 12
patpat78
it works thank's
Message 10 of 12
patpat78
in reply to: patpat78
Hello
other problem the csv file works fine but how it works with the nozle or steel valve
for exemple we have GF pipe and flange in 110mm but we use socle buterfly valve in nd100 in the reality it works but autocad doesn't want to combine these component ..
any idea ?
Message 11 of 12
rajsekarpillai
In AutoCAD Plant3D we use end connection rule to connect the parts. You can change the rule in the project settup -> End connections.
e.g. Pipe + fittings+ valves looking for same ND to connect the parts.
To fix your problem, Go to Catalog editor and change the ND size to 110 and update the same part in your spec and use it.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Autodesk, Inc.
Message 12 of 12
GF has nice working libraries/specs/catalogs for PDMS and SmartP3D. They say they have AutodeskPlant3D in their radar but cannot give a timeline.
https://bim.gfps.com/
Is anybody in Autodesk following this up. Plant3D is falling way back in the race.
”Boost
