AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Fusion Weld Dots
4 REPLIES 4
Icegambit
592 Views, 4 Replies
Fusion Weld Dots
I'm having an issue with the weld dots coming out on the ISO drawings. I'm using PPL end types and so the fastener is a Fusion weld, but when i go to create the ISO it comes back with Glue dots. Going into the connector config file I can change the glue joint to weld and everything works fine. Then there is the problem of actually wanting the glue welds to show up with the PSW end connection. Does anyone know where or how to change where the connection fasteners are pulling information from. I assume it would be as easy as changing fusion weld fastener to pull from another SKey, but no idea where that is located.
4 REPLIES 4
Asimo5000
in reply to: Icegambit
I am also looking into the same thing.
I noticed if you use any other type of end code, also with an unrelated SKEY but have "Fusion Weld" joint in your settings, you get no glued connector.
That said it must be PPL is pulling the Glued connector, but thats not mentioned in the SKEY block map, and not really in the isoconfig
dave.wolfe
in reply to: Asimo5000
Known issue, it's on the bug list. No word of when it will be fixed.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
JameseeT3KVM
in reply to: dave.wolfe
Hey Dave,
I know this is an oldie, but ever here anything more about the Fusion Welds?
Erin
dave.wolfe
in reply to: JameseeT3KVM
I believe it was fixed in 2016 Ext 1.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
