AutoCAD Plant 3D Forum
Font Size of Line Numbering and cutlist
8 REPLIES 8
Message 1 of 9
krisharun84
1335 Views, 8 Replies
I am having a trouble in setting the font size of Line Number Annotion displayed in the Isometric. Even after I keep the text style height as 2.5mm, in isometric it is getting displayed with a height of only 1.7mm around. How to fix this, as-similar the annotation text height of cutlist is displaying around only 1.2mm even after this was changed in the Iso-symbol editor to 2.5mm.
Arun
8 REPLIES 8
Message 2 of 9
krisharun84
in reply to: krisharun84
Attached herwith the Isometric drawing marked with clarifications seeked for clarify.
Message 3 of 9
krisharun84
Tomislav Golubovic- I am awaiting for your reply, as I didn't get the answer from Autocad partner to our company.
Message 4 of 9
So when you edit the Isometric Style, and go into the Iso Theme's, you've nominated the Annotation size as 2.5mm?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 5 of 9
krisharun84
Yes, did, you can check your own sample isometric and see, even if u keep the text height as 2.5mm, the font size of line numbering is not getting changed.
Message 6 of 9
krisharun84
I don't understand why more time is being taken for reply from Autodesk side, I always expect a genuine support engineer to answer for a query in 1 or 2 days if not the time frame for answering should to be informed. Keeping silent is what?????
Message 7 of 9
Actually I've been chasing it up and have to confirm settings, plus its the weekend here.
Tomislav Golubovic
Autodesk, Inc.
Message 8 of 9
Venkatesan.A
Arun,
Can you try the settings mentioned in the attached document and let me know if that is what you were looking for?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 9 of 9
Hi Autodesk Support,
I thing the Autodesk People not understand what we are meant,
 Our Problem When we are using the option in the Isometric Settings to show the Part No. Or Tag No. Or .....,
 As isometric whine generating the Isometric drawing there are no options for Changing Size From 1.7 to 2.5
 Because it’s Already 2.5mm by default, Hope Understand our Problem
Ahmed Helal
”Boost
