AutoCAD Plant 3D General
Distinguished Contributor
Message 1 of 10 (1,100 Views)
Flow Arrow On Isometric 2012
1100 Views, 9 Replies
10-20-2011 04:28 PM
There is a dimension appears on Flow arrow on Isometric. and if the line is insulated it also gives an Insulation break. is there a setting to turn this off?
Message 2 of 10 (1,045 Views)
Re: Flow Arrow On Isometric 2012
10-31-2011 11:19 AM in reply to: rlpacle
guys, anyone? i havent figure out how to turn off this very special feature..
Employee
VickyADSK
Message 3 of 10 (1,031 Views)
11-01-2011 01:39 AM in reply to: rlpacle
Turn off Insulation break annotation:
Go to IsoConfig.xml from project style folder. e.g. Project name\Isometric\Check_ANSI-B
Comment out selection below string or Delete it.
<PropertyBreakerScheme Name="InsulationLimit" AnnotationStyle="SpecBreak" Tag="Left Right" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="NotBoltOrWeld" Field="HasInsulation" DefaultAnnotationStyle="Standard" DefaultL-->eaderStyle="Always" WordWrapLimit="10" EnableMultiple="true" />
Btw, the issue regarding dimension for Flow arrow has been identified. Thanks for your reporting it.
Vicky
Autodesk Plant Solutions
Valued Contributor
neonade
Message 4 of 10 (981 Views)
11-17-2011 08:06 PM in reply to: VickyADSK
Hi Vicky,
Is your reply the answer to the flow arrow issue?
Thanks and regards
Employee
VickyADSK
Message 5 of 10 (977 Views)
11-17-2011 09:09 PM in reply to: neonade
My above reply is to solve insulation annotation for flow arrow.
Remove dimension of flow arrow:
Go to isoconfig.xml file to modify, e.g. Project\Isometric\Check_A2\isoconfig.xml, add below red string.
<Filter Name="Fitting" Value="NOT (Type = 'Pipe' OR Type = 'Gasket' OR Type = 'REINFORCEMENT-PAD' OR Type = 'Flange' OR Type = 'Bolt' OR Type LIKE 'Valve*' OR Type = 'Olet' OR Type LIKE 'Instrument*' OR Type = 'Support' OR Type LIKE 'Elbow*' OR Type LIKE 'Cross*' OR Type = 'Weld' OR Type LIKE 'Tee*' OR Type LIKE 'Y-*' OR Type = 'FLOOR-SYMBOL' OR Type = 'FLOW-ARROW')" />
The issue has been fixed in our next release.
Thanks very much.
Vicky
Product Support
Message 6 of 10 (951 Views)
11-21-2011 03:11 AM in reply to: rlpacle
The issue where a dimesion is being placed for the flow arrow has been escalated to our development team so it is something that is under current investigation.
Dan
Dan Scales
Active Contributor
OmarGT
Message 7 of 10 (828 Views)
01-03-2012 08:17 PM in reply to: Dan.Scales
Excuse me, is the placed-dimension issue already solved? Thanks in advance
Employee
VickyADSK
Message 8 of 10 (823 Views)
01-03-2012 08:23 PM in reply to: OmarGT
Yes. We have already fixed  both above 2 issues in Plant 3D 2013. Thanks for your concern!
Vicky
Message 9 of 10 (585 Views)
08-27-2012 12:26 PM in reply to: VickyADSK
What about in 2012? is there a work around or Hot fix for this problem? we're currently using 2012 on our project. thanks!
Valued Mentor
Rich.O.3d
Message 10 of 10 (479 Views)
10-08-2012 04:50 PM in reply to: VickyADSK
Ok...i have this flow arrow edit inplace.
I have a line that starts with a section of Rubber lined pipe from the pump then after FIT/DIT, the line continous an in a poly pipe spec.
on the poly section, flow arrows are aok
on the rubber lined section, the flow arrows are dimensioned!
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
