AutoCAD Plant 3D Forum
Floating Nozzels
1 REPLY 1
aedwards83
248 Views, 1 Reply
Floating Nozzels
I am trying to render a shot of some vessels with some simple piping attached.  I am using a Plant3D to FBX to showcase workflow.  The nozzels on my tanks seem to float in the air (See Picture) and do not attach to the head of the tank. Also, I notice that my pipes are fairly boxy, and reveal a lot of edges.  Is there a setting which will smooth out my edges and possibly fix the nozzel issue?
Alex
1 REPLY 1
Are you using a straight Plant 3D drawing from the project? I would suggest to open the drawing in the project and then use EXPORTTOAUTOCAD. This will create a new drawing file. Use this file and see if you have better results.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
”Boost
