AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Flanged Pipe Not Displaying Correctly
8 REPLIES 8
Message 1 of 9
tgarr12
743 Views, 8 Replies
I am trying to create a lined pipe specification.  I have the fittings and pipe defined in a catalog and the com[ponents from the catalog in a specification.  The flanges on the fittings display correctly but the flanges on the pipe do not.  Plant 3D makes the connections at the joints but will not display the flanged end of the pipe.  Can anyone help with this problem?
TGarr
8 REPLIES 8
Message 2 of 9
TRdesigner82
in reply to: tgarr12
Screen shot???
Message 3 of 9
tgarr12
in reply to: TRdesigner82
Here is a screen shot.  The program treats them as connected but will not display the flanged ends of the pipe.
Message 4 of 9
TRdesigner82
Are you using the proper "Flanged Pipe" in your catalog? See attached for example...
Message 5 of 9
tgarr12
That looks like the shape (CPP_F_F_) I used to create it in catalog builder.
Message 6 of 9
TRdesigner82
Do your dimensions seem similar? (attachment)
Message 7 of 9
tgarr12
I had numbers in the W1, W2 and D23 columns.  When I changed them to 0 it worked.  Thanks for the help.
I have one more question.  In a long run of straight pipe, is there a way to show the intermediate flanges in the piping between fittings?
Message 8 of 9
TRdesigner82
I don't really have an answer for you on that one. Hopefully someone else can chime in and point you in the right direction...
Message 9 of 9
tgarr12
Ok.  THanks again for the help.
”Boost
