AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Field Fit Weld label size in Isometrics
3 REPLIES 3
philip
1101 Views, 3 Replies
I've added some Field fit welds to my model and the come though onto my iso but size is about 70% of the balance of text and also 30 iso, I've tried looking through the isoconfig file but have not been able to find were the size etc are able to be modified. any one able to help
3 REPLIES 3
Arun_Kumar_K
in reply to: philip
there is no option available in iso setup to change the sizes of field weld and line number display in Isometric.
philip
in reply to: Arun_Kumar_K
There's not option to added a line into the Isoconfig.xml file to adjust the size of this item?
Thank you for submitting your question in our discussion forums. Currently it's not possible to customize this in the ISOConfig file.
The issue that you describe has been sent to our development team as an enhancement request. We will keep you posted on the updates.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
”Boost
