AutoCAD Plant 3D Forum
FLANGE CONNECTIONS TO VALVES
1 REPLY 1
417 Views, 1 Reply
HOW DO SET THE FLANGE TYPE TO AUTOMATICLY CONNECT TO A VALVE?
WHEN I PLACE A VALVE IT COMES IN WITH AN ORIFICE FLANG NOT A WELD NECK FLANGE.
1 REPLY 1
jabowabo
You need to make sure you have a compatible flange in your spec and set it's priority above the orifice flange in the spec editor.
