AutoCAD Plant 3D Forum
FATAL ERROR: Unhandled e06d7363h Exception at fd84aa7dh
10 REPLIES 10
Message 1 of 11
J.Koch
1779 Views, 10 Replies
we have a problem with Plant 3D on the following machine:
WIN 7 32 AND 64-bit.
While using Plant 3D 2010 more times a day the system is crashing an the message in the headline appears.
Has anyone an idea what this message means?
Thanks, Julian Koch
10 REPLIES 10
Message 2 of 11
Ian_Matthew
in reply to: J.Koch
Hi Julian,
What are you attempting to do when the error occurs?  Any further information would be very helpful.
Ian Matthew
Technical Marketing Manager
AEC / Plant Solutions
Autodesk, Inc.
Message 3 of 11
J.Koch
in reply to: J.Koch
Hey Ian,
you're right. I thougt there would maybe a list with the error messages.;)
Oh, and I'm not quite sure, if I posted it, but they work with AutoCAD Plant 3D 2010.
The message appeares when they work with AutoCAD Classic (not Plant 3D or P&ID) in the AutoCAD Plant 3D. When thy want to go from one drawing into antoher one or when they want to open a second drawing.
Hope that helps. I don't have more informations.
BR, Julian
Message 4 of 11
J.Koch
in reply to: J.Koch
the problem is solved. It was cuased by the server they worked on.
BR, Julian
Message 5 of 11
Ian_Matthew
in reply to: J.Koch
Julian,
Thank you for the follow up.  Glad you found the cause.
Ian Matthew
Autodesk, Inc.
Message 6 of 11
goran.rissveds
in reply to: J.Koch
Hi Julian
I hope you read this in spite of the fact that you found the solution to your own problem.
We experience the same problem as you described.
Could you, please, tell me in what way did the server have any impact on the event?
How did you solve it?
Hope you're  my savior!
Göran R
Message 7 of 11
Hochanz
in reply to: goran.rissveds
Yes, Julian. Please provide the details from the server side that resolved this issue.
From what I have read so far, this could be related to
.NET FRAMEWORKS 4.0 - this is not verified. Could the moderator (Autodesk) confirm or deny this possibility.
steve
I modify when required !!
Message 8 of 11
J.Koch
in reply to: J.Koch
Hey,
sry for my delayed answer. I'm not quite sure now, 'cause it was afew days ago... So, what the customer told me, that the internal capicity of the server was too high. All their drawings are stored on this server.
I don't know, if they have a new server now or if they find another way to work.
Hope that will help you!?
BR, Julian
Message 9 of 11
PeterQuinn
in reply to: J.Koch
I'd like to encourage everyone to push the "send the information to Autodesk" button when AutoCAD crashes. These crashes go into a database and both the Plant team and the AutoCAD team sort through the data and use it to fix bugs. So, this information is useful and does help us fix bugs.
Thanks!
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Message 10 of 11
auto_2013
in reply to: J.Koch
I got the same error message for version 2013! Have you guys figured this out after all!Smiley Sad
Message 11 of 11
auto_2013
in reply to: PeterQuinn
Hello there! Although I installed Microsoft .NET Framework 4, I got the same error message for Autocad Plant version 2013! I do appreciate if you let me know how to figure this out!
”Boost
