AutoCAD Plant 3D General DIscussion
Member
james.smith
Message 1 of 4 (400 Views)
Expansion Joints
400 Views, 3 Replies
01-03-2014 03:39 AM
Hi All,
I have been compliling a a company catalogue/spec in Plant 3D and I cant seem to find expansion joints anywhere.
Does anyone know where I can download them or am I going to have to create these manaully?
Many thanks,
James
Employee
KenFauver
Message 2 of 4 (305 Views)
Re: Expansion Joints
01-09-2014 01:19 PM in reply to: james.smith
When creating new components in the catalog you can use existing component scripts that resemble what you are trying to represent. Follow these steps to create an expansion joint.
1. Open Spec Editor
2. Select the Catalog Editor tab
3. Open the catalog you want to add the expansion joints to
4. Pick the Create New Component button
5. When the Create Component dialog open change the following settings
NOTE: The Primary End Type will be changed later leave it at BV for now
6. Pick the Create to add the new component to the catalog.
7. Now fill out the remaining data to complete the entry.
NOTE: All Size Parameters on newly created components are filled out as metric by default. Modiify the values as needed per your standard.
Make sure to select the Save to Catalog button to save your edits.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
Member
james.smith
Message 3 of 4 (280 Views)
01-13-2014 02:45 AM in reply to: KenFauver
Thank you Ken for your response.
It was a great help.
Many thanks,
James
Active Contributor
Asimo5000
Message 4 of 4 (268 Views)
01-13-2014 12:53 PM in reply to: james.smith
There is also an SKEY that you can use that looks like an expansion joint.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
